Knickell
Here is a quick look at the LED Projector Headlamps and LED Taillamps on the 2021 Ford F-150.
These particular headlights are the dual beam style and what Ford calls "LED Projector with Dynamic Bending Headlamps". There haven't been any photos or videos showing this style of headlight on an F-150 yet. I also had not seen them turned on and in use until I found this truck at the auto show, so I had a partner work the switch and got this video for you all!
I found it interesting that the amber colored strip in the middle of the headlight housing does not appear to be a turn signal. Rather, the signals/emergency flashers are located at the bottom of the light as you'll see in the video. It took a while for us to figure out the knob that activated the lights because it was not working as it typically would because of the battery maintainer the truck was hooked up to, but you can still get a pretty decent look at how they work!
These LED Projector headlights are included on the F-150 starting with the Lariat 502A High package and higher trim levels. This F-150 was the Limited model.
This is a similar video of the LED taillights in action. The rear LED lights are also standard on Lariat 502A High and above.
I’ve also attached some up close photos of the headlights for you viewing pleasure!
C-shape signature LED lighting, headlights off
Close up of C-shape signature LED lighting
LED Projector Headlights with signature lighting on
LED Projector Headlight Close Up
LED Projector Light Close Up Part 2
LED Taillights Full View, brake pedal depressed. LED CHSML (Center High-Mounted Stop Lamp) and LED Bed Light also activated.
LED Taillights with headlights on showing red C-shape signature. Also see LED bed light.
LED taillights with brake pedal depressed
