Annoying and overzealous are understatements; the recirculate self canceling is infuriating and I have barely driven my truck this winter, mainly because the Toyota 4Runner that I also drive minds its own damn business when I turn recirculate on. Is it easier to subvert the top speed governor than the anti-fog scheme?
Monstrous and inconceivable is more in line with Ford’s bizarre execution of this diabolical aberration forced upon us.
There’s enough of a workload driving safety in the city that I don’t need any additional distractions. The fact that other people are already distracted is exactly why I don’t want to be burdened anymore than I already am.
Once again, there’s already a button for that!
There’s a fair amount of information on page two and three. The way I see fixing it is either a kill switch on the door to lock it in whatever state it was last in. Or maybe even an in-line module right before the switch with a flip-flop in it that would actually remember when you press the switch and then turns it back on when the light turns off.
I’m thinking for my next road trip though, that I might just tape off 90% of the fresh air inlet under the hood.
I will buy. Willing to pay hundreds for a solution I don't have to invent myself.I was thinking something I could make on a 3d printer and put in between the actuator and the lever. A model that has either a manual or electrical connection that allows you to put the door anyway you want, while the actuator and the programming THINKS its still getting the better of you. A little over the top I am sure but if I can do it, I will sell yall my product! LOL
@Zyvin So grateful for your effort. I will try to copy your work this weekend.Well, I finally gave up on finding a Forscan solution. Disabling the anti-fog strategy works pretty well when it’s hot outside, and you’re running the a/c; but not so much with cooler outdoor air.
1. There is only one inlet door for the outside air. There are many other doors/flaps but they just direct the air to whichever vents you have selected.@Zyvin So grateful for your effort. I will try to copy your work this weekend.
Questions (as best as you know-- I know you didn't design the truck):
1. Is there only one fresh air inlet door, so that fixing this does the trick? (when I considered physically chasing down a solution, I had visions of multiple inlets that I'd be unable to see/reach).
2. I can't make-out the green & orange wire in your picture. Did you take any other pics while it was open you could share? Same on the circuit diagram-- I think the forum re-sized that down, if you can re-post, or let me know where to find that. (I'm a noob)
2a. Which wires did you choose for your backlight power?
3. My setup is a little different (e.g. I have a fuse for the 120v where you have your 12v outlet), is there a way I could confirm I have the correct wire, before cutting, if my wires are different colors? Like should I look for a wire that shows a +12v on my multimeter when recirc is active, and zero when un-pressed?
4. Any issues removing that HVAC face from the dash? Just a couple of trim clips?
5. Finally, let us know a paypal email address or some way we can send our thanks.
I sent you a PM. That looks like the C228B connector and mine was in the C228A connector.Holy crap, there's a "green with brown stripe" and "brown with green stripe." Feels like the end of The Abyss. @Zyvin , your picture is pretty clear that the correct wire is green with brown stripe (mostly green", but if you're online and can confirm while I've got the dash open, I'd appreciate it.
I'll send pics of the slightly diff procedure (and harness) for the non-console guys. (the order of wires seems slight different-- was trying to use that as a double-check)
My experience with Ford's re-circulation anti-fog strategy system.I will buy. Willing to pay hundreds for a solution I don't have to invent myself.
OMG that is the perfect gif for their idiot strategy.My experience with Ford's re-circulation anti-fog strategy system.
Looks like it’s meant to be there…nice.There it is gents-- my sasquatch switch. We owe a lot to Zyvin for this.
